Disables the generation of ICMP router advertisement messages on one or all VLANs.
name | Specifies a VLAN name. |
Disabled.
If no optional argument is specified, all the IP interfaces are affected.
The following example disables IRDP on VLAN "accounting":
disable irdp vlan accounting
This command is available on all platforms that use the Edge, Advanced Edge, or Core license. For information on the licenses available for each platform, see the Switch Engine v33.1.1 Licensing Guide document.
